I have purchased a Logik L22DVDB11 and would like to connect some external speakers to the set, on the back of the set there are connections for a right speaker and a left speaker, but when i connected a new pair of speakers taken from a new small stereo system that i also purchased, nothing happened and the tv was turned right up to max volume (100), volume is quite low and does not seem very loud to me at all. any ideas. I have looked in the handbook in the box but it does not say anything about the external speakers.
SOURCE: Loud humming noise from new hdtv
hello, the speakers are fualty or have a shorted connection if they came with the tv contac your seller and arrange for a replacement imediately dont wait. since they are giving you feedback dont use them they may cuase other fualts in your tv, any component thats cuases hum or noise when pluged into the tv should not be used at all.
one important thing is to have a grounded plug this also may cuase fualts down the line,
if posible get a power line conditioner or ups (uniteruptable power supply)
flat panels are very over protective you dont want the tv to start blinking. since flat panels have built in protection circuts any slight short or fualt may cuase the wide screen to go into circut shutdown mode and this will cost you more if the speakers create a short in your audio circut it may damage your widescreen internal boards and cuase a system shutdown circut (red light flashing no picture)
contac your sellers site let them know your speaker are cuasing a loud hum
and that you will need the speakers replaced these are definitely fualty
if you dont have any coverage or you got the set as is then dont take any chances use other speakers.
if you are electronically inclined you can open these up and find out whats wrong with them internaly it may be a loose connection, since opening up the equipment may void your warantee contac the store first see what they say..
good luck happy holidays
SOURCE: Sharp Aquos LC-26D4U sound problem
Well, apparently this is a huge problem with many flat screen TV's. They surpress the volume output from all external sources (like DVD players) so you don't blow up their tiny speakers. They just expect you to add on a home theatre system to boost the volume their small speakers cannot handle. This is a real problem if you are in a boat or RV and do no have the space or electrical capacity to do this. I had the TV checked out and Sharpe said it met their factory standards so there was no help there. We have had to go with a small amp & speakers just to hear the TV & DVD movies etc. They need to put better quality speakers in these TVs. The video is awesome, now work on the audio guys!
SOURCE: Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
SOURCE: Want external speakers for Sony TV Model KLV-S32A10
This is really easy. A pair of simple bookshelf speakers will do nicely. Simple speaker wire can be run to them, to extend whatever cable they have. If it's only screw terminals they have, so much the better.
You'll have to attach RCA plugs to the ends going to the TV, but that's easy.
SOURCE: what is easylink connection? Wireless? HDMI?
The Easylink is Philips name for HDMI CEC which allows multiple HDMI devices to control each other with one remote.
As for the sound...it looks like there is only one audio out and it's in the form of coaxial cable which isn't very helpful.
What I would suggest is that you tap the audio coming from the input. So I'm assuming your TV is connected to a cable/dish box. Use the audio out from that to power your headphones or external speakers. This will likely mean you can't use the HDMI or will need a splitter, but at least it will solve your issue.
