If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
