My kindle light stays yellow does the colour change when fully charged.?
It is supposed to turn green when fully charged. There is also a battery charge indicator on screen.
http://www.amazon.com/gp/help/customer/display.html?nodeId=200728630#battery
Check this out :
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: Kindle locked up and now can't get it to turn on.
I have the same problem. The screen saver is partially frozen on the screen on the upper right corner and then blank down the rest of the right side. The rest of the screen is readable and I'm able navigate (turn pages, select different books, etc).
Did you figure anything out? Help!
