I switched it off one night and when I tried to switch it back on the following day.... nothing happened.... no hum... no flashing lights... no error codes... nothing... just totally dead. I've replaced the power cable with one that I know works, however it still doesn't do anything. I've plugged something else into the power socket and that works. So I know it is something inside my printer... Please help.
SOURCE: canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
SOURCE: Prints some blank pages
Hello Mike,
Please try to refill the catridge and if it dint help you then replace the Catridge ,which will surely pay off you..Thank you...
Please Post on how things turned or for further assistance..!!
Regards!!...
SOURCE: Canon SmartBase MP730 Photo Printer producing
sounds like your mechanism is really unhappy..is this still under warranty, by chance?
SOURCE: ERROR SIGNAL CODE 5 FLASHES
Error also refers to the EEPROM for the printhead. I would reset the EEPROM and see if that helps.
Printer servcie manual here and it will show you how to do it:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
Hope that helps
SOURCE: Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
