Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
Make use of the Windows XP's My Pictures Slideshow screensaver for this purpose. Follow the steps:
Using Paint brush (mspaint.exe), create 10 or more images with a Black background in each. Open each image file and embed your company logo in it, in (place it in random areas, one in each image).
Create a folder for the image files you've created, and place the images in that folder. Assign this folder read-only permissions for all the users.
Now, configure the screensaver under your user profile. In the My Pictures Screensaver properties, do the following:
Set the folder where you've stored the image files
Set the interval using How often should the pictures change slider.
Uncheck all the checkboxes at the bottom of the dialog
Click OK and save the changes
Set the Screensaver Timeout to a preferred value in minutes
Test the Screensaver in your profile to see everything is fine
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in
hand.Insert a memory stick or SD
card that has the images you want to use.When the image is displayed, press the pause button on the remote.Then touch the screen to bring up a set
of icons on the bottom.If you do
not see an icon with a hand, press the arrows that are in a circle until you
do.Once you see the hand, press
it one time.It will save the
image onto the internal memory.You will find the image in the screen tab in settings, under all the
stock images."
go to Start > PROGRAMS > Dockware. Now click on the top left hand corner of screen.
Click on 'Setup' to uncheck the box to Automatically start Dockware.
