Stihl HT 75 pole saw is great. If you want easy to pruning tree by the best pole saw go to the link The Ultimate Remington Electric Chainsaw Reviews
SOURCE: looking for a manual for a stihl pole power saw
Your local Stihl dealer can order the manual for you. It might be free or there could be a small charge for shipping. Either way, it's worth having the manual and Stihl WANTS you to have the manual. Be sure to have your model number and serial number with you when you go to the dealer.
SOURCE: I have a Stihl ht101 pole saw that is not oiling
Remove the bar and chain and run the saw. Does oil come out of the side port? If not, check the pump, lines, and in-tank filter. If ok, clean all the holes in the drive end of the bar including the small holes that pass oil to the chain slot. Compressed air helps here. Clean the chain slot. Oil the chain manually after assembly.
SOURCE: stihl ht75 wont start
Is it still under warranty? If so, take advantage. If not, remove the spark plug and check for spark with a clean plug. If nothing, likely the ignition module has died or the stop switch is shorted. If has spark, put some fuel in the plug hole, reinstall the plug and try to start. If runs for a moment, then concentrate on the carburetor and fuel lines. Make sure the primer button pumps fuel into the bulb when pushed several times. Make sure the carburetor is tight to the cylinder and the end plates on the carb are screwed tightly. Make sure the choke plate closes when the control is operated. Check the fuel lines for kinks or splitting. Hope this helps!
