My mother bords smd chip does not work so display of screen does not appear.my laptop nme is toshiba a135-s2276.pls help me
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Are you sure it is the ?SMD? chip? I think you are referring to the ATI Radeon XPress 200M IGP video/graphics card? If you look at the screen, does the screen aoppear faintly? This is a known problem with this laptop, and having a similar model, and the exact same problem, I can tell you that this is a problem with the LCD FL Inverter, which is a board located at the base of the LCD screen that handles backlighting for the LCD. Below is the ordering information for this chip, and you can easily replace this yourself.
LCD inverter for Toshiba Satellite A135 series (A135-S2246, A135-S2256, A135-S2266, A135-S2276, A135-S2286, A135-S2296, A135-S2306, A135-S2356, A135-S2376, A135-S2386, A135-S2396, A135-S4407, A135-S4417, A135-S4427, A135-S4437, A135-S4447, A135-S4457, A135-S4467, A135-S4677)
Toshiba Part number is K00043960
SOURCE: pci drivers
You do not need pci drivers, you need the drivers for the hardware
that you plug into the pci slot. Your motherboard runs the pci.
hello
my toshiba satellite a135-2276 is intermittent problem i suspect that the problem is motherboard, sometimes it works for 10 minutes then automatic shutdown. when i turn it on again the display is good only for 30 seconds again turn it off...please help me to fine solution for my laptop
thanks in advance!
how to reset password baios toshiba A135-s2386
