Whenever someone external dials into the phone system, just my set beeps once as the Auto Attendant answers the line. While my set is not ringing, it would be nice to eliminate this 'notification' whenever someone calls either Line1 or Line2. Also of note, it does not happen when dialing internally or once the line is activated.
SOURCE: Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
SOURCE: Meridian Norstar M7310 -- Phone's buttons seem disabled.
unplugging and replugging is the first step. Is your shift button stuck?
Dan
SOURCE: Our Automated Attendant for our Norstar M7310 is
assigning messages is done by
feature 983>1020000>AA>Table>table 1>Greeting Type
depending on how you have the business hours times set it'll play the greeting you want. Typically I set the greeting type as morning:1, afternoon:1, Evening:1 and Non-business:4. then under business hours I set them up as mon- fri morn:0800am, aft:0800am, eve:0800am and nonb: 0500pm. sat and sun as morn:1200am, aft: 1200am, eve:1200am, and nonb: 1159am
press Rls when finished
that way when a caller calls between 8am and 4:59pm they get the day greeting and from 5pm to 7:59am they get the night greeting (greeting 4) saturday and sunday play the night greeting all day.
Dont forget to record greeting 4 as your night greeting.
SOURCE: We have a Norstat Meridian M7310 phone system - is
THE PHONE IN THE BACK IS THIS A NORSTAR PHONE. WHAT IS THE QWEST VMAIL AND WHAT DOES THE NORSTAR SYSTEM LOOK LIKE . SOUNDS TO ME THAT QWEST IS SUPPLING VMAIL AND NOT YOU OWEN NORSTAR COULD YOU CLARIFY THIS FOR ME.
SOURCE: We have a meridian M7310
First of all, make sure you're plugged into the headset port of the telephone and not the handset port. Pressing the Handsfree button should change from handset to headset. You can't use the speaker phone with the headset plugged in.
