Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Posted on Oct 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
Help please think it requires a new pump please confirm
  • Angelblue Feb 19, 2009
    I have a Hotpoint WD640T washer dryer. It is flashing error code F-05, we have removed the pump and got 63p out of it but the error code is still flashing, can anyone help please.
  • zbeven Apr 04, 2009
    Hiya I have had the same problem, is it expensive to repair, f-05 code flashes and wash stops, cleaned filter, checked pipes not blocked, filter was clogged but ok now, then f-11 flashed up, regards zoe
Danny
Level 2:
Sergeant:
  • Expert 160 Answers
  • Posted on Feb 22, 2009
Danny
Expert
Level 2:
Sergeant:
Answers
160
Questions
0
Helped
63255
Points
538
F05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2000
Points
Hi, I had the same problem (F11), and ended up having to buy a new pump (£22) which did the trick. What was annoying was that my washing machine was only just over a year old and the old pump has become rusty!
Dai Boyce
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Sep 21, 2014
Dai Boyce
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
158125
Points
858
Take the back of the machine off.
You will need to try and tilt the machine forward or lay on the floor.
The bottom right you will see the pump witha pipe from the bottom of the drum.
Undo the plastic circlip with a small screwdriver by prising it apart. Then undo the clip onto the pump motor. Once undone check to see what rubbish has been collected. Empty by clicking the plastic and removing the floating ball ( which looks like a pingpong ball ) you will more than likely find old socks , handkerchiefs or other small items lodged and stopping the water pumping out
Just reassemble and Refit in the reverse to taking off.
  • Dai Boyce
    Dai Boyce Sep 21, 2014
    Forgot to mention , if you have a small tray put it underneath as a bit of water will come out of the system and the pipework you remove.
A
Anonymous
The f 05 error is a blocked filter
Hotpoint Aquarius wm750 won't fill with water
Dear Chris.
Here is offered a list of fault codes Error Codes Hotpoint Service
How to understand fault codes
Identifying Hotpoint or Indesit Error Codes
Hot Point Manual Link
Download Manual Hotpoint Service
It is possible your water supply is to low or your screens may be blocked at the inlet attachment to the washer. The other scenario a sticky or failing pump solenoid ; by which a direct replacement of the pump assembly may be required. Try to lubricate and actuate valve by hand if possible.
Fare Well.
2answers
What is f4 and f7 error code
F04 Error code is "Pressure switch jammed on empty"
F07 Error code is "Heater relay stuck"
Both would require you to dis-assemble the washer to get to each part for checking / replacing.
http://www.hotpointservice.co.uk/help-and-advice/error-codes/
My hotpoint wt640 will not empty and has an f11 code
Hi
Error F11 means that F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked. This may also have happenned if the washer is not draining. It may have happenned due to drain pump is not working. Try and check the drain pump, if the connections to the pump are fine. Please post back for further assistance.
Daniel
4helpful
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
1helpful
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Repair manual for hotpoint wt960p
The error code does not mean that the pressure switch is faulty, it is indicating a fault that affects the function of the switch.
The problem is actually a blockage in the pump or pump filter.
To rectify the problem, do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction hers as well.
This should solve the problem
Please leave feedback for my solution.
Thankyou.
5helpful
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
1helpful
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
1helpful
Hotpoint wt965 f04 error
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Not emptying
what that signals is the impellor on the end of the pump is jammed or loose. Check to make sure it is free.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
