Microsoft Windows XP Home Edition English for PC Logo
Anonymous Posted on Apr 01, 2017
Windows reapir windows
How To Repair Your Corrupted Windows System Files for Windows XP There are times when for some unknown reasons, the registry entries or system files get corrupted. Here is one method of restoring those files using a program called 'webfldrs.msi' without reinstalling the whole of Windows. The program is located right there on your PC and can be run from c:\windows\system32\webfldrs.msi If it's not on your system, you can download it from here;- http://rapidshare.com/files/297062455/webfldrs.rar Here is the procedure;- - Insert your Windows XP CD into your CD-ROM - Run webfldrs.msi You will see the following dialogs. Just follow the instructions.
Level 3:
  • Microsoft Master 19,187 Answers
  • Posted on Apr 01, 2017
Microsoft Master
Level 3:
Answers
19187
Questions
0
Helped
4345909
Points
82261
The link that you listed is at best dubious and this could be a malware implant.
5 Related Answers
Anonymous
  • 871 Answers
  • Posted on Jan 24, 2009
SOURCE: Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Anonymous
  • 433 Answers
  • Posted on May 11, 2009
SOURCE: Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
Computer hardware and networking support
  • 4281 Answers
  • Posted on Dec 07, 2009
SOURCE: Windows XP Home Not Booting
For that you need to recover error on hard drive then you can see repair option.
For that insert windows disk or recovery disk in cd/dvd rom.
Then boot your computer with it set first boot device as cd/dvd rom in bios.
Then follow the procedure select "R" for recovery console.
Then type in prompt "chkdsk /r" then press "y"
then it fix error on hard drive.
Then restart computer then it search the previous windows then you can see "r" for repair previous windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Anonymous
  • 261 Answers
  • Posted on Dec 24, 2010
SOURCE: my computer is not able to boot, it gives msg as
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
badi souleiman
  • 278 Answers
  • Posted on Jun 29, 2011
SOURCE: \windows\system32\config\system..the pc will not start
hello my brother may you need to repair you windows with the oreginal cd
2answers
My system is verry slowe working
It could be many reasons:
Your laptop/desktop doesn't have much memory or diskpace available
Your laptop/desktop may have spyware, malware, or viruses
Your laptop/desktop may have antivirus software scanning in progress
Your Internet connection is slow
Your laptop/desktop may have device driver issue.
tip
My AutoCAD software does not start anymore.
Hi.
If AutoCAD was starting until recent times, and suddenly stopped working, that means that there is either a corrupted registry or system value, or that one of the Autocad files is damaged.
Below the solution for Mac and Windows.
If you have Windows:
The first fix that you can try is doing a system restore to a date before the problem occurred. System restore will bring all settings and registry values back to the chosen date, so that if the problem is a corrupted registry, then Autocad will restart working.
Most of the times, System restore will be enough to fix the problem. If system restore does not solve the problem, it means that one or more of the Autocad files may be damaged. In that case the only solution will be uninstalling and re-installing back the design software. You will need a disk and an installation key to reinstall AutoCAD.
Try first doing a system restore, that usually works.
Here instructions on how to do system restore:
How to perform System Restore on Windows XP
How to use System Restore in Windows Vista
If you have a Mac:
On a Mac try first using repair permissions. Close all application and log off. Log back on. Go to Finder, Applications. Utilities, Disk Utility. After the message saying "Getting Disk Information" select Volume, then Repair Permissions.
If that does not work reinstall Mac OS or do an update.
If still no luck, you have to reinstall AutoCAD using AutoCAD CD and installation key.
Regards.
on Mar 27, 2010 • Autodesk AutoCAD 2005
4answers
My pc was very slowly running
Your machine is old, there's not much you can do. Remove any programs you don't use, stop programs from starting-up with the OS, and increase your RAM: http://www.crucial.com/index.aspx
2helpful
3answers
RES SIR, PLESE GIVE ME THE SOLUTION ABOUT ' WINDOW FILE PROTECTION MESSAGE' i.e. fills that are required for windows are replaced by unrecognized versions.To mentain system stability windows must restore...
click start menu, then run and type regedit.exe click ok
the look for this registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
and find the value SfcScan
right click over SfcScan and click Modify
change current value to 0 and click ok
restart your computer and that will take care of the issue.
The SfcScan value in the following registry key has three possible settings:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WinlogonThe settings for the SfcScan value are:
  • 0x0 = do not scan protected files after restart. (Default value)
  • 0x1 = scan all protected files after every restart (set if sfc /scanboot is run).
  • 0x2 = scan all protected files one time after a restart (set if sfc /scanonce is run).
3answers
My pc is very slow
-Can you provide more information about your issue?
-Are you using Windows XP or Windows Vista or Windows Seven?
When you say slow, is it slow when you are on the internet or slow when accessing or the computer or generally slow like everything is running slow?
2helpful
My system file and registry files are missing or corrupted
Yeah, that happens. You can reload your OS and that should resolve the issue. I suggest that you consider replacing the unit as XP is so old it is no longer supported. You will find that Windows 7 works fine, however files are located in slightly different places, no biggie.
The problem with your old machine is that when you finish, you still have an OLD machine, prone to failure. It takes very little repair time to eat up most of the cost of a new machine. The new machine (in theory) should last you longer.
2helpful
5answers
My feiends Dell Net book is very slow, I set the system back and Installed AVG removed Mal Wares it ran good, When i took it back it went to running very slow again~!! So do I have to wipe it and...
There are many free and effective registry cleaners. You can use Ccleaner (which I highly recommend). You can download Ccleaner from here (click here). It's bundled with System Cleaner, Registry Cleaner and other utilities. Run the System cleaner and the registry cleaner. Check the startups and also verify all the services from the Task Manager.
Sometimes some virus can't be removed if they really infected some files, in that case, you better reinstall the windows (full format), but remember, during the backup or file transfer, don't simply copy/paste, instead use the wizard like "backup" or "Files and Settings Transfer"..
If you need further help, let me know.
Good luck.
2answers
New computer dell inspiron 570 running windows 7-connected for 3 days. came back to use it this afternoon and the media player has lost it's sound and you can hardly hear the PC -the system tells me =media...
Microsoft Windows Media Player is a free media player software that comes with the personal computer version of Windows operating systems. The software supports basic file formats such as WMV, WMA, AVI, MP3, and ASF. The player included in Windows XP gives you the power to create your own CDs, search and organize digital media on your PC, and copy files to portable devices such as CDs and pen drives.
Fix Windows Media Player Problems
Corrupted and missing DLLs files, incorrect registry entries, and outdated files are some of the causes of Windows Media Player errors. Covered here are a few steps that you can take to fix common problems.
C00D11CD: Unknown Error
C00D11CD errors occur when an operating system component or some other program encounters an error and does not communicate it to Windows Media Player. Due to its generic nature and multiple reasons for occurrence, there is no specific solution to this problem.
If you encounter the error when trying to play an AVI or MPEG 2 file, then most likely, you do not have the correct codec version installed on your system. To fix a Windows Media Player problem related to codec, search for the required codec on the Internet, download it, and update it on your system to play the required file.
Windows Media Player uses Digital Rights Management (DRM) to authorize copying files to a CD or to download them from an online music store. If you do not have DRM authority to copy a particular song, you will not be able to play it and the error will pop up.
Windows Media Player uses the wmadmoe.dll file to encode files. If something goes wrong with this file, you may get the c00d11cd error when you try to copy songs from a CD to your hard disk. To fix a Windows Media Player problem in this situation, you must register the DLL file by running the command ‘regsvr32 wmadmoe.dll’.
80040155: Interface Not Registered
If this error occurs when you try to burn songs into a CD, then the most probable cause is that the required player files are no longer registered on your system. To fix this error, try to reinstall your Windows Media Player or download and install a newer version of the player, if available on the internet.
800C2EE2: Action timed out
This error occurs when your Windows Media Player is unable to connect to a server due to problem in the network, and therefore cannot play protected audio/video files that you download from an online music store. Incorrect Internet Explorer security settings might be the cause of this problem. To fix this, open Internet Explorer and select Tools-Internet Options-LAN Settings. Next, clear the Automatically detect settings check box.
C00D0FAA: Cannot rip the files
The error usually occurs when you try to rip CDs to MP3 format. Existence of entries from an earlier player version in the registry might be the reason behind this problem. One way to fix this problem is by adjusting the audio quality. However, if you want to maintain the audio quality, then to fix this Windows Media Player problem, open the Registry Editor by running the Regedit command and navigate to the subkey given below.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Sett ings\MP3Encoding
Here, open ‘LowrateSample’ and delete the value displayed in the Value Data box. Select OK and exit Registry Editor.
Many times errors also occur when there are corrupt files on the system or there are invalid DLL entries and other related incorrect entries in the system registry. For this, you must try to download reliable registry cleaner software from the Internet and scan your registry for invalid entries. Using registry cleaner software, you can easily and efficiently fix Windows registry problems, and make your PC free from irritating errors.
Errors can occur in Windows Media Player due to outdated files, missing or corrupt DLL files and incorrect registry entries. Most of the time, you can fix Windows Media Player problems by updating missing files or by upgrading the player to a later version. Additionally, to prevent registry-related problems, you can use a registry cleaner software to regularly scan the registry and eliminate invalid DLL entries and corrupt values from it.
2answers
My pc is running slow
Hello
There could be several reasons for this:
[Software type]
1. There are too many trash files (temporary files left after some program crashes or uninstallation; temporary internet files and small amount of free memory after all)
2. Your computer Registry should be cleaned and optimized
3. Your hard disks should be defragmented
4. Some components have bad or corrupted drivers
5. Viruses, trojans and other malware may slow down your PC performance
6. Too many programs running at Startup or in your SysTray
7. Inacurate size of Virtual Memory
My advice would be to use this " Faster Computer Now" guide at:
http://tinyurl.com/yzvb3eg
[Hardware type]
1. If your computer wasn't fast from begining, consider upgrading RAM and/or Processor (see your computer mainboard's documentations for available options)
2. Hardware mullfunction
Of course there are more reasons, but I just mentioned mostly common
That's a registry error.
In order to remove this, either you need to manually download all the missing or corrupted files.You may reinstall the windows XP or if you wish you can google for certain registry fixers softwares like :-
http://www.instant-registry-fixes.org/how-to-repair-windows-installer-error-1706/
Any further help, let me know.
Thanks.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
