Our Lutron NetWork lighting control system has failed. It seems the lower board replacement part #HW-REPL-Processor needs repair or replacement.
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
SOURCE: Main control panel
need to have a service company check the bottom oven elements first, the replacement part has only a 90 day warranty on it. if it is the control again ???????????????
SOURCE: Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
SOURCE: Lutron Dimmer Not Dimming But On/Off Works
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
