Invicta 5525 watch and I need to reset the chronograph hands to the o position
SOURCE: I can't figure out how to adjust the offset chronograph
This is to adjust the seconds hand or minutes hand for the chronograph. Pull the crown out either one click or two ... depending on the models. Squeeze and hold the top and bottom buttons at the same time (timer stop and reset buttons). Hold down together for 2+ seconds. The chronograph hands should reset by spinning around and stopping at 0. If the don't stop right at zero, you can now adjust where they stop. Leave the crown where it is in that same position out. Press the top chronograph button and hold it down for fast movement or short presses for fine movement to adjust til it stops at the top. This will adjust where the seconds hand stops. Then click the bottom chrono button once. Repeat what you did with the top chrono button and it should allow you to fine tune the position for the next dial, and so on. When you are done, press the crown back in all the way to the normal position.
SOURCE: reset chronograph minute and hour hands to zero
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
SOURCE: On a Invicta Men's Off-Shore Russian Diver Quartz
It isn't a fault and can be adjusted. Follow this link and find out how to....
http://www.invictawatch.com/
Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Testimonial: "Thank you so much, now i dont have to mail it back in and i know how to actually work it now, your awesome! "
