No power to cd player or ceiling light grand vitara 2003
fuse, called dome fuse is blown, or radio fuse.
fuses that look bad, are, fuses that look good, may be...........
check fuses with an ohmmeter, fuses that look good can have very tiny cracks and are not good, only an ohmmeter works, on fuses with 100% accuracy. (a volt meter works in circuit even better !!!)
Did you test the dome lamp to see if it really works?
pull it , put across 12v battery ,does it glow?
did you look at the radio. and see if it has its own inline fuse?
did you hot wire the radio power wire to see if the radio even works at all?
if you have DMM with voltmeter this is so very easy to trace.
ask.
