Sport & Outdoor - Others Logo
Posted on Oct 14, 2008
Tent I have a Colunbia Sports Dome tent that has 5 poles. I have lost the directions & not sure which poles go where. Can you help??
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Oct 15, 2008
Anonymous
Contributor
Level 1:
Answers
41
Questions
Helped
7223
Points
92
Well, you should have Three (3) longer poles and Two (2) shorter. Two (2) of the longer poles will be the basic construction poles. They will basically make an "X" across the top of the tent making the four courners of the tent. The other longer pole with also go across the top of the tent and right through the "X" made by the other two (2). This will push out the sides and make is "dome-like".
The two (2) shorter poles will go on either side of the enterance. These will hold up the sides of the tent to give you more volume space on the inside. Not exactly nessasary but if you want more than one or two people to fit inside, you'll need these.
Hope I helped.
I have a North Point screen tent and I would like to replace the poles. Anyone know where I could order them from?
Hello, Amy -
Apparently Northpoint Adventure Gear was a private label sold by Sports Authority stores. Sports Authority filed for bankruptcy in 2016 and ceased doing business. For a while, after Sports Authority ceased doing business, information on its website directed those interested to Dick's Sporting Goods.
I only find a tent pole repair kit being sold by Dick's Sporting Goods, currently, in stores only:
https://www.dickssportinggoods.com/p/coghlans-tent-pole-repair-kit-16cghufbrglsstntpcat/16cghufbrglsstntpcat?
If you still have the poles for your Northpoint tent, do not toss them out, just yet.
I have seen a variety of replacement tent poles for sale through Amazon. You MAY be fortunate enough to find replacement tent poles which will work with your Northpoint tent for sale there.
Best wishes.
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
Ozark trail tent wmp1711 poles
There are a few places you can look for replacement poles for your Ozark Trail WMP1711 tent.
1. Manufacturer's Website: Checkthe manufacturer's website for replacement parts or contact their customer service department to inquire about replacement poles for your specific model of tent.
2. Outdoor Retailers: Visit outdoor retailers that carry Ozark Trail products, such as Walmart or Academy Sports + OutOutdoors. They may have replacement poles available for purchase online or in-store.
3. Online Marketplaces: Check online marketplaces such as Amazon, eBay, or Craigslist. Sometimes you can find individual sellers who are selling replacement tent poles for various models. Make sure to confirm that the poles are compatible with your specific tent model before making a purchase.
4. Tent Repair Services: If you're having trouble finding replacement poles, consider reaching out to tent repair services. These professionals may be able to create custom replacement poles or suggest alternatives that would work for your tent.
Remember to provide specific details about your tent model, such as dimensions or specifications, when searching for replacement poles to ensure they are compatible with your tent.
Manual for a northwest territory portland dome tent 17' X 9'
I NEED POLES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT SAYS IT SLEEPS 8 PEOPLE AND HEIGHT IS 70" IT SAYS NEXT TO THE UPC BAR CODE IT WAS MADE FOR KMART.
I CALLED KMART THEY SAID SEARS.COM HAS SOME REPLACEMENT KITS THAT WOULD WORK THERE IS LIKE 8 DIFFERENT KITS. COULD SOME ONE TELL ME WHAT KIT WILL WORK WITH THIS TENT. THANK YOU INADVANCE.TIM
#WMT-5100 PENTAGON 3 DOME CONNECTION TENT MANUAL
Need instructions for the WMT-5100 3 dome tent.
5helpful
Swiss Gear Tent - Broken Poles SG33071F
Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
4helpful
2answers
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Top Sport & Outdoor - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
