I leant on the knobs on my stoves 607MFsingle electric oven earlier today and the left hand side display has changed to say dEnO instead of a temperature. I'm guessing I have put it in demo mode but I can't get rid of this diplay and the oven now won't heat up etc. Can you tell me how to put it back to normal?
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
SOURCE: I HAVE BOUGHT A SECOND
STOVES don't have any and from past experience are reluctant to help. I now have a copy in .pdf format for anyone who wants it. All I need is an email address to send it to you.
SOURCE: reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
SOURCE: Morning I have a Stoves EFA600H
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
