Model 88058 Honeywell Wine cooler, my mistake, the capacitor in the upper LEFT corner had bulging rupture disc groves, replaced, with higher voltage, about $1.50, now works great
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
The flashing Orange light means the charge is flashing. The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
Turn the power off.
Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
Locate the Auto Button the lower left corner of the Control Panel.
Turn the power back on.
Press
the buttons in the following sequence, releasing each button after each
time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the
Control Panel should go out, and the error code should clear.
If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
Program the copier as if you were going to make 14 copies.
Press the green [Start] button to store the reset code. The copier will return to the ready position.
There are actually some certain meaning on the red light and green
light showing different information to user. The summaries are: 1) Green On, Red Off = Printer Ready. 2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up. 3) Green Fast-Flashing, Red Off = Printer off-line. 4) Green Slow-Flashing, Red Off = Processing Data. 5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing. 6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset. 7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted. 8) Green Off, Red Off = Printer power is off. 9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode. 10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
thanx i was being blinded by the flash
