Home Logo
leslie bilton Posted on Jan 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiring diagram for a p i r to a light - Home
Anonymous
Level 3:
  • Master 565 Answers
  • Posted on Jan 24, 2012
Anonymous
Master
Level 3:
Answers
565
Questions
0
Helped
269921
Points
1490
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Wiring diagram 2001 Chevrolet 3500
https://www.autozone.com/repairguides/GM-Full-Size-Trucks-1988-1998-Repair-Information/WIRING-DIAGRAMS/WIRING-DIAGRAMS/_/P-0996b43f80c90e70
Daewoo tail light wiring diagram
Hi. Thanks for your question. For light wiring diagram you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
3answers
Brake light wiring diagram for a suzuki motorcycle
Stacy, Check the attached links,instruction and guides on motorcycle brake lights diagram. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Suzuki Motorcycle Brake light wiring diagram Google Search
how to wire motorcycle brake light switch Google Search
Installing brake lights
Simple Motorcycle Wiring Diagram for Choppers and Cafe Racers
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
My rear wiper, defroster and licence plate lights stopped working on my 2007 suzuki swift but when I open the rear hatch the licence plate lights come on . Any ideas what's wrong?bad ground?
[PDF]Wiring Diagram.pdf - Ken Gilbert
ken-gilbert.com/wrx/mans/99.../Wiring%20Diagram.pdf
Each connector number shown in the wiring dia- ... Rear defogger cord (Ground). Fuel tank cord,. Roof cord, ... circuit. Then check the switch, relay, fuse, ground, etc. 4. .....Rear wiper motor. Rear wiper ... License plate light RH. Tail light LH.
#? license plate light - Circuit Wiring Diagrams
circuitswiring.com/tag/license-plate-light/
2008 Volkswagen Newbeetle Main Fuse Box Diagram 2008 Volkswagen Newbeetle ...Parts: rear window defogger, shift lock, battery positive voltage, interior light, A/C clutch, ... brake light, daytime driving light, wiper and washer system, vacan, fuel pump, central ... 1997 Suzuki Geo Tracker Left Dash Fuse Box Diagram.
#? license plate light - Circuit Wiring Diagrams - Page 3
circuitswiring.com/tag/license-plate-light/page/3/
Audi A4 Engine Fuse Box Diagram Audi A4 Engine Fuse Box Map Fuse Panel ... mirror control, wiper, washer, horn, brake light, cruise control, heated rear window, ... 2003Suzuki Aerio Dash Fuse Box Diagram 2003 Suzuki Aerio Dash Fuse Box ... rear defroster, fuel injection controller, radio, A/T controller, hazard light, ...
2helpful
2answers
Need diagram on wiring harness for 2002 ford f150 showing ground wires and wiring for starter/celanoid can you help?
If you need it for the truck car radio then some of these sites will help you. http://www.fordf150.net/forums/viewtopic.php?t=68020 http://www.modifiedlife.com/2002-ford-f150-truck-car-radio-wiring-diagram/ And from what i understand this is the wiring: Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio ground wire: Black/Green
Car Radio Illumination Wire: Light Blue/Red
car stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Gray/Light Blue
Left Front Speaker Negative Wire (-): Tan/Yellow
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Orange/Light Green
Left
Rear Speaker Negative Wire (-): Light Blue/White
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
I put a lot of work into this answer so i hope it helps. If it doesnt then contact me and i will get it right for you but this should be the correct diagram.
1helpful
Need help with the wiring diagram for my 92 Dakota, has not brake lights or blinkers
www.wiring-diagram.com
You can get any wiring diagram for any vehicle. It will cost about $12 and it's well worth it. It will give you the complete diagram bumper to bumper.
12helpful
3answers
Stereo wiring diagram
2006 Ford F150 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Light Green/Yellow
Car Radio Ground Wire: Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
