Electronics - Others Logo
Anonymous Posted on Oct 14, 2008
How to formate my disk devices
I cannot formate my disk devices MY 2GB GENX flash disk neither writes/reads nor delet data
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
479
Points
I've GENX flash disk 2GB, I forget my password for Carry It Easy program, Now its capacity only 14.8GB, What can I do to fix and reformat.
Domenico Grillo
Level 2:
Habit-Forming:
  • Expert 170 Answers
  • Posted on Jan 21, 2019
Domenico Grillo
Expert
Level 2:
Habit-Forming:
Answers
170
Questions
0
Helped
92972
Points
411
It is probably damaged try a different computer
Genx pe4ndrive.when I insert in lap top click to open it is displays not formatted.when I clic formatting button it is displayed that i will loose all memory of pen drive it's data.
Try it on an other computer... if that fails, it might have developed bad sectors (spots) reformat and do a scan, which writes and reads all memory locations... might be corrupted and/or broken, but try another computer first to make sure it is not a driver issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
2answers
Hi there. When I try to format the disk, I have "The disk is write protected" message on the screen. I can play the data on the disk,but not to add or to format it. What to do? Thanks in advance....
Hi George,
If you right-click on the removable device and go to properties, when in there uncheck the read-only box and click OK.
If that doesn't sort it check the actual card itself and see if there is a switch or slider on it that can be moved.
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
1helpful
I try to format but it erros or delet it comes back
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
I am not recognising kigston data traveller
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
NOTE Formating the USB flash drive will delete your data.
2helpful
Genx 4gb flash disk problem
the most defalt of option is reinstal the driver and check in the Device Manager the usb you  have 3 usb root hub,1 enhanced pci to usb controler,update and try again,it should work.
1helpful
Micro sd 2gb card, not read.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
5helpful
3answers
Remove Write Protection
Remove Jet Flash Write Protection Insert the mini CD that came with the USB Flash disk. Start JF Utility.exe in the JF Utility directory. If it complains that the disk is write protected, choose "Continue" Choose "Partition" Answer "Yes" to losing all your data (Since this becomes a problem usually after formating the disk in WinXP or Win9x, you will most probably not have any data on there in any case) Choose "Public Area Only (Single Partition)", Then "OK", Then "OK" again. Unplug the device, reinsert device, and voila!- no more dark secret areas or write protection on your disk!
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
