Computers & Internet Logo
Posted on Jan 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I watch videos from off my computer on my pandigital because it won't let me?
Michael Green
Level 3:
  • Master 3,799 Answers
  • Posted on Jan 24, 2012
Michael Green
Master
Level 3:
Answers
3799
Questions
0
Helped
600270
Points
10177
Copy them to a USB stick and watch the movie from the USB stick. Or set up your computer to "Stream" music and video. Then , as long as your Pandigital is part of the same "Homegroup" or "Workgroup" , you will be able to "share" your movies and music. Both Devices must be set up to share the information on each other.
Forgot password
Go to Barnes & Noble's website on your computer and select the option to create an account. Enter your full name, email address, debit or credit card information and select a user name and password when prompted.
If you have a Barnes & Noble account, skip this step.
Power on the Pandigital Novel and tap "Settings" on the home screen.
Tap "General, and select the "B&N Account" and "Password" fields and enter your Barnes & Noble account login information.
Reading ebooks is not the only activity you can enjoy with the Pandigital Novel.
The multi-functional device will also allow you to listen to music, watch videos and browse through your favorite images.
The Pandigital has a speaker located in the back of the device and an earphone jack to accommodate your listening needs.
To get started, you will need to either download media from a computer or purchase ebooks from Barnes & Noble online.
Downloading Media
Connect the Pandigital Novel's USB cable into the compatible mini USB port on the right side of the device. Plug the other end of the USB cable into the computer's USB port.
Click on the computer's desktop "Start" menu.
Choose the "My Computer" or "Computer" folder in the desktop Start menu.
Double-click to open the "PD_Novel" drive in the My Computer/Computer folder.
Inside the drive there are four separate folders "eBooks," "Photos," "Music" and "Videos."
Drag compatible media files stored on the computer to the compatible folder inside the "PD_Novel" drive with your mouse.
For example, drag audio files to the "Music" folder.
The Pandigital is compatible with text formatted as ePub and PDF, audio files formatted as MP3, AAC, WAV and OGG, video files formatted as MPEG-4 and images formatted as JPEG, BMP, PNG and GIF.
Disconnect the Pandigital Novel from the USB cable.
Playing Media
Press and hold the "Power" button, located on the left side of the device until the boot up message appears on the screen.
Select a media option in the "Application Quick Launch Bar" at the bottom of the screen: Reader, Music, Videos or Photos.
Tap the desired song, video or image and tap "Play" or "View."
Tap the "Pause/Play" and "Previous/Next" options to control the file or go to the next listed file.
Setting Up Wi-Fi
Turn the "Wi-Fi" button, located on the top of the device, to the "On" position.
The Pandigital Novel will automatically scan for local Wi-Fi Networks.
Tap the desired network from the list of found networks.
Enter the network password, if prompted. Then tap "Connect." When connected, tap "Next" to continue.
Purchashing eBooks
Tap to go back to the home screen.
Select "Bookstore" from the home screen.
The Barnes & Noble bookstore will open in the Pandigital Novel screen.
Search the website for ebooks to purchase.
Tap on the book cover and select either "Buy Now" or "Get Free Sample."
Tap "Yes" to download the media cover to "My Library" when prompted.
Go back to "My Library" on the home screen and tap on the media cover.
Confirm to download the ebook to your Pandigital when prompted.
The entire media file will download.
http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
Barnes & Nobel
http://www.bn.com/
1helpful
2answers
I can't finD an owners manual for 7
Hi Donna Mitchell...
Here is some phone numbers for Pandigital, hope it helps.
Bud
Sales: 800.606.6969 or 212.444.6615
Customer Service: 800-221-5743 or 212-239-7765
Pandigital support: http://www.pandigital.net/?pageid=125
Having difficulty finding a video converter compatible for pandigital novel 7
Freemake Video Converter.
You'll want to use the Android option under the covert selection.
Works like a charm. :)
Used wrong charger on pandigital novel
I put my pandigital on the charger and it sparked and now it's not working
4helpful
My pandigital ereader won't connect to wifi all of the sudden. I've tried everything. The manual said to reset, and now it's dead. Can't get it to turn on. Any suggestions?
I rare case,the wifi module can disconnect for it socket.
It's usually cause by mishandling the unit.
If it's under warranty then you should send it in for repair.
====== The DIY method is to power off the unit.
Place a large soft towel on a table.
Place the display face down.
Apply GENTLY pressure (side to side and top to bottom) on the back of the unit.
PLEASE apply pressure gently!!!!!!!!!
With some luck,you will press the wifi card back into its socket.
2answers
Pandigital will not start up
1. Is there voltage from charger to plug (Volt Meter Needed) 2. Has unit been dropped or wet 3. How long has unit been down?
21helpful
Why cant i watch youtube videos on my pandigital ereader 7??
You need to download the Youtube app http://www.mediafire.com/?4jzay95u32ggf7k
Grand Canyon Tech
Grand Canyon Tech
