We have attempted to charge the camera via USB cable in both a power outlet and on computer, and with both the original provided and a new cable and original charger, but absolutely no response has been given by the camera to suggest recharging. We have explored charging options on the camera with what charge still exists, but nothing has changed. The computer will not even read the device.
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
SOURCE: Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
SOURCE: Camera will not charge, shows
It could possibly be the battery or the charger itself.Try purchasing the charger it self.Use the old battery to see if it will charge it. If it does not charge you may have to purchase a new battery.as well.
