Added a garment and hit pause-keeps flashing 1:16 left of cycle. Can't resume cycle or clear it to start over. Tried hitting hold to start button, control on button to clear it, and pause/cancel button.
SOURCE: Washer control panel flashing and won't restart
I don't know if this is a real solution but it wokred for me. I just unplugged it for about 10 minutes and then plugged it back in. The flashing stopped and I was then able to resume normal function.
SOURCE: Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
SOURCE: MY DUET SPORTS DOES NOT DRAIN.
your pump is probably plugged or the impeller on the pump motor is not turning properly and jamming.
SOURCE: had to stop my whirlpool duet sport front load
Try unplugging for 30 minutes, then try to start again. If this doesn't work you probably have a contol board or door lock problem. Good Luck, Appliance Specialists
SOURCE: HIT PAUSE CANCEL BUTTON TO ADD A GARMENT AND IT IS
unplug the machine wait 5 minutes and plug back in the board should go back to normal adding a garnment should be done on the washing not on the rince
