Each time I use my bagged microban 2200 watt dirt devil vacuum cleaner it hardly picks anything up. I have checked for blockages and I've cleaned the filters. There are no other visible problems that I can see. Please help. It's quite new and I'd rather not replace it if it can be fixed. Thanks
SOURCE: miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
SOURCE: vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
SOURCE: Vacuum has new bag but won't pick up dirt. Cleaned
It's clogged somewhere. Disconnect the hoses where you can and check for obstructions. Run a coat hanger down the hose if you need to to clear the obstruction.
