New flooring nailer, only 4-5 hours of use. Air is leaking past the trigger. nailer still works but air is constantly leaking so that the compressor has to keep up with demand. When you pull the trigger in the air stops.
Please help, need to get this floor down,
Thanks,
KB
Couple of things there are o-rings inside that trigger assy. they are either pintched in or dry. next there could be internal rubber hoses inside the gun. might need replacing. lastly the hose or o-ring going to the back side of the ram is leaking or broken. here is what i would do. you sound pretty handy with your tools so i would get somewhere clean start taking the gun apart thouroghly noting where everything went and go untill you find the problem. but first i would shoot a couple of drops of oil into the air input on the gun then hook it up and fire a few off and see if it clears up, if not then start takeing it apart. I CAN NOT STRESS ENOUGH....DO THIS ON A CLEAN SERFACE WITH YOUR HAND CLEAN. i chased a leak around in a pnumatic hammer for 3 days all because it wasnt clean on the inside..
