ATT Uverse running through Denon Receiver for Surround Sound Denon AVR 3300 Receiver Phillips 50PFP5332D Plasma TV Screen with HDMI1 (cable connected) and HDMI 2 (Apple TV with optical digital audio cable Jack 2) Sony DVD (AV1 with optical digital audio cable Jack 1) I cannot see the Denon's Setup menu on TV screen to add the new optical digital audio Jack 2 configuration. Did I setup video incorrectly?
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF]
AVR-3300/1
3.3E*
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an
HDMI cable to the TV. This will give you a high def picture (set up the
PS3 to output the max resolution your TV displays). That will take care
of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3
menu, you have to change the audio settings to output the sound via the
optical cable.
Finally to get sound out of the receiver to the speakers, you have to
setup the receiver source input. For example if you setup the PS3 to
play thru "VCR" input, then you have to make sure the VCR input is
setup to use either optical 1 or optical 2 for sound (whichever one you
have the optical cable plugged in from the PS3).
SOURCE: how to do a hard reset on a denon avr 3300
Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
Testimonial: "worked like a charm thanks for the help"
