Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Oct 13, 2008
Bizhub C650 (Minolta printer, copier)
For the last 3 weeks Minolta are trying to fix the current problem we have with our 3 month old machine. As soon as we put paper into the Automatic document feeder to copy of scan the machine gives the following "error" message: Original already on original glass". there are nothing on the glass and you can't copy or scan from the feeder. They have reload software etc, but still no fix! HELP
  • Anonymous Mar 02, 2009
    I m getting often the same message and moreover The automatic feeder dont reconize the A4 size in automatic paper
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
635
Points
I usually go into service mode change the setting from table 2 to table 1 that solves the problem
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
94268
Points
90
Setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
My colours do not align on my bizhub c650
run the registration procedure. do you have any oil can showing on the bottom of the control panel P-21. P-28 etc
1helpful
What does the Error code C-225B means on the Konica Minolta?
I am unable to fix the problem C225B in Konica C450 please help me i have replaced all the tonner unit and Developer kit also.
Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
2helpful
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Duplexing problem on Konica Minolta Bizhub C650
This is a software thing.  Usually if you use the hole punch in the finisher this doesn't happen.
Try putting the paper in the other direction and see if that fixes it.
If it doesn't fix the problem you will have to run one side at a time.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
