My Hotpoint Washer dryer is showing error code 2& 4, pressure sw stuck on full, washing still in machine. Door lock not releasing. What do I do next?
SOURCE: REMOVING FLITER ON A HOTPOINT WD420
The filter is inside the machine. If you machine is still under guarantee I would try and get it done that way. Otherwise turn off the power and pull out the machine to get a the back.
Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. THe filter is inside. Losen the clip and pull away the tube take out the filter and clean it. When you replace it don't forget to put the ball float back in and check its well fixed by runing a spin cycle before sealing up.
SOURCE: Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
SOURCE: the hotpoint WD640P washing machine is stuck on 'test'
turn the machine on while preesing the on and start buttons together until dOFF appears.
SOURCE: does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
SOURCE: Hotpoint WD420 Dryer heater relay
You must check for overload try to messure the amount of clothing you adding to the machine, and try to restart by unploging the aparat from the wall outlet, wireing diagram are located usualy on the back of the aparat.
