I have my camera plugged into the electric outlet and plugged into the computer USB. When I turn it on to play mode to try to transfer files, the screen is black, nothing comes up, and the computer doesn't recognize any device. When I switch it to record mode, it comes on and will seemingly let me record. When I then switch it from record mode to play mode, it stays in record mode (lets me record) and I can't see or access my files as I should be able to. At this point, I'm most concerned about getting my files off the camera (Baby's first Christmas is on it ; ( ) Any help would be appreciated!
SOURCE: Will not play back
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
SOURCE: Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
SOURCE: my video camera wont let me record or play
Greetings bianca50,
There is a known issue with a small button that becomes stuck causing your camera to display this error message. I would suggest ensuring this button is not stuck on your camera by putting the battery on a bit forcefully. This should eliminate the error.
Thank you,
Agent Dort
Go Ahead. Use Us.
SOURCE: Lens Cap Error
You have a defective CCD imager - the part of the lens that receives the image. Will need to be replaced.
