The dishwasher goes through any cycle but does not draini. I used an Allen wrench and took out the screw in the white piece below the filters to see if there was an obstruction. I pulled out two seeds and checked the small filter tucked inside as well. Then I tried to run it again but we still had water. Any ideas?
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
SOURCE: Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
SOURCE: what size allen wrench to open panel of the bosch
It is not an allen wrench you need but a torx wrench (looks like a 6-point star). DO not try af open with an allen wrench or you will strip the screws.
