My hotpoint washer/dryer is adding a drying programme to every wash I do even though it is not being selected... I have tried resetting the machine iaw the instructions by holding the start button in for 5 seconds but the problem persists... Any help would be much appreciated
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
If every wash programme ends with drying cycle then it's very likely the drying switch is disconnected from main pcb by connector and wiring (spin cycle effect over time). Open washing powder door, undo 2 screws at top and remove front cover carefully by pulling to left and then off. Easier if you can take top off but a simple workaround
I had same issue and resolved by disconnecting the wiring on back of switch,cleaning contacts and the restoring connectivity
exactly same problem
my BWD129 adds an unwaned drying cycle randomly, i.e. some times it does not. But there is no system to the madness.
