Question about Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men
How to set time om digital/analog jules jurgensen
3 Suggested Answers
SOURCE:
escapement
  • 2338 Answers
SOURCE: How do I change the battery of a Jules Jurgensen pocket watch.
First you have to get an eyeglass and examine watch caseback. Can you see the joint or is it monoblock? If there is joint, get strong knife and press into it. Some of watch casebacks are very tight, so, apply great pressure but do not let the blade slip or you will damage the movement.
If the case is monoblock, then you have to open it from dial side.
Be very carefull when doing it as any slip of the blade will damage your watch.
Good luck.
Posted on Dec 19, 2008
escapement
  • 2338 Answers
SOURCE: Looking to adjust the size
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Feb 25, 2011
I have a Jules jurgenson watch with serial# 752161 and JXJ stamped on back of it too it has 17 jewels unadjusted Swiss and says Jules jurgenson Corp can u tell me anything about it
The company is Danish, but they were sold in the US by a distributor. Yours is an older one, prior to the name change in 1811, or after 1936.
Jules Jurgensen was a watchmaking company. It was founded by J?rgen J?rgensen in 1740 in Denmark, when J?rgen J?rgensen went into partnership with Isaac Larpent, under the name "Larpent & J?rgensen".
Upon J?rgen's demise in 1811, his youngest son Frederik took over the company and changed the name to "Frederik J?rgensen".
Jules J?rgensen produced many watches in Switzerland. Jules J?rgensen was sold to a company in the US in 1936, and the watches were still produced in Switzerland until 1957, at which time it was first documented that the watches were made by others and have their name put on them.
The company was sold to Mort Clayman in 1974, a watch distributor in the US. According to the company's website, they Mort Clayman died in January 2010, and the company was closed by his family. In 2011, Dr. Helmut Crott, owner of Urban J?rgensen & S?nner acquired the rights from the Clayman family.
https://en.wikipedia.org/wiki/Jules_Jurgensen
The prices vary wildly!
Jules Jurgensen Diamond Watch eBay
Read this thread which is very informative
Can someone tell me more about this Jules Jurgensen
Lots of pictures of them, see if you can find yours. All check the All tab.
Jules jurgensen watch Google Search
Feb 20, 2018 | Swiss Watches
I bought my Jules Jurgensen watch in the Airport Terminal in San Francisco on my way back to Dublin Ireland 3yrs ago.First of all one of the "Small hands" came adrift and "floated around...
While the firm does not appear to be selling watches any more, they still repair them, although they are in America!
Go to http://www.helbros.com/ for their contact details.
Jan 22, 2011 | Jules Jurgensen Watches
Can i get a phone no. for jules jurgenson co to get extra band pieces because my watch is too tight to wear
mcdevito75 Here, I did a Fast Search and found a customer service number for Blue Dial a Jules Jurgensen Dealer, nothing on the main company though. Blue Dial may be able to help, it"s a toll free number, 1-877-518-9396 Hope this helps.
Sep 13, 2010 | Jules Jurgensen Watches
Hi there hope you can assist me. My first question to you, and thanks lots I have a Jules Jurgensen watch, and it arrived brand new without a battery. 1) Does a battery for a 7837BR normally...
All watches should arrive with battery fitted. As now there are too many variations of watch movements, it's impossible to tell exact battery code without seeing the watch. Nearest watch repair shop will be able to tell you that.
Jul 30, 2010 | Jules Jurgensen Watches
Watch does not work after changing the battery
mcdevito75 here, You can try, double check the battery instalation in the watch, If all is good, try to pull out the stem and move the hands as if setting the time, then push stem back in. It"s also possible you have a weak or even dead battery, even though it was bought new.
Jul 02, 2010 | Jules Jurgensen 7793IF ( ) : Swiss Quartz...
Watch Instruction manual
The best thing to do for instructions for a Jules Jurgenssen is to contact them. You may also try retailers who carry their product.
Jules Jurgensen Helbrose International
101 West City Avenue
Bala Cynwyd, PA 19004
USA
Corporate Phone: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-220-1233cb_transparent_r.gif
Sep 22, 2009 | Watches
Good luck.
Dec 18, 2008 | Jules Jurgensen Fisherman 7485 Wrist Watch
Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men Logo
76 people viewed this question
Top Jules Jurgensen Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
