Ignore answers provided. There is no online manual for a Jenn-Air 88370 drop in downdraft range. There is a wiring diagram in the wire tray under the controls. There are parts diagrams at many locations. It's very simple to use. Preheat uses both oven elements. If your clock/timer still works then turning the timer to just right of top center will result in a bell being struck about once a second. For the oven timer the left dial is duration the right is start time. The accelerated cleaning at 550 is not like the 1960's self cleaning. The oven coating catalyzes grease to oxidize, but if it's gloppy it will have to be cleaned manually. The downdraft blower itself can be checked through the door to the left of the oven and the lift-out slot. Check often, clean as required. The motor is all but unavailable but it lasts forever if the blower isn't filled with grease. The blower switch is hard to find from Whirlpool. The original OEM switch is still available, read the marks on the switch. The flexible blower exhaust boot will also fill with grease periodically, it's a dirty job, but it only needs doing every 5-10 years. The aluminum grease filters are still available. They last a very long time, just put them in the dishwasher when dirty.
Confirm the model number and type to download manual from the link below.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JDR88370&siteCd=JA_EN_US&userType=Consumer
Hope it helps.Thanks!
Ken.
