Ya le puse los driver pero no se oye no se que mas puedo aser si me meto a ajustar el volumen si se mueve las barras el amplificador de las bocinas si amplifica solo que de la tarjeta no sale la señal cuando reprodusco musica si se mueve mueve las imagenes de wuindos pero no se oye gracias
Ever try google translate, do that and post?
amazing results.
my sp is like 1/10 useful. (horrid is the word)
ok will do it for you.
here we go....
quote.
"they can not help me to have my computer audio
I have already put the drivers but I can not hear.
what I can not hear,
if I start adjusting the volume
if the bars are moved by the amplifier of the speakers
if it amplifies only that the signal does not come out when I play music (from what source)?
if it moves the images of windoz but you can not hear thanks.
end quote.
you lost me with all those IF's 4 of them.
NO PC stated, just a motherboard, why post with NO PC>?
NO OS stated why post lacking the most important part
Windows what?, 98,ME,2k,XP,Vista,W7./8/10
XP and older is virus magnet never use XP ever.
what Speakers. are the Speakers pulled it no AC power ?
is the speaker volume (at speaker ) turned and in windows.?
step one is windows sounds, not mp3, not cd music
not web music not movies of any kind , local or on web
local sounds in windows control panel is the first test always
click sound, then click sounds tab
click asterisk.
click test,
does that worK????? simple no?
reverse translated, omg, this will be poor.
"me perdiste con todos esos IF's 4 de ellos.
NINGUNA PC declar?, apenas una placa madre, ¿por qu? postear con NO PC>?
NING?N sistema operativo declar? por qu? la publicaci?n que carece de la parte m?s importante
¿Windows qu? ?, 98, ME, 2k, XP, Vista, W7. / 8/10
XP y m?s viejo es virus im?n nunca use XP alguna vez.
que oradores. ¿Los Altavoces no lo han desconectado?
es el volumen del altavoz (en el altavoz) activado y en las ventanas.?
El primer paso son los sonidos de Windows, no mp3, no cd music
no la m?sica web ni las pel?culas de ning?n tipo, locales o en la web
sonidos locales en el panel de control de Windows es siempre la primera prueba
haga clic en sonido, luego haga clic en la pesta?a sonidos
haga clic en asterisco.
haga clic en prueba,
¿¿¿¿¿Eso funciona????? simple no?
como
does the windows test button work>
easy as 1,2,3,4 steps to test sound.
this always must work
the acid test is using ear buds on the green 3.5mm line out jack on the rear of the PC,
do buds work?
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
SOURCE: tengo un proyector dell modelo 2300, lo compre de
yo tengo un proyector de la misma marca y modelo pero sin la
lampara si gustas te lo vendo barato o me vendes la lampara cel 01 4611886077 luis enrique
Hi alexcp2011, please try English.
a win that.
