Expert
- Posted on Oct 12, 2008
Re: Polaroid " 3211 TLXB red light no power up?Ive...
Hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
200-P00-MLT666A-BH PCB - POWER SUPPLY MAIN FOR POLAROID 3211TLXB TV - $179.99
05A30-1A PCB - LOGIC FOR POLAROID 3211TLXB TV - T315XWO2 $139.99
200-700-GF271BH PCB - BUTTON SET FOR POLAROID 3211TLXB TV - $79.99
200-001-GF271CH PCB - INTERFACE FOR POLAROID 3211TLXB TV - $79.99
E206453 PCB - VOLTAGE INVERTER FOR POLAROID 3211TLXB TV - 4H.V1448.291 $129.99 I found cheap parts at: Discount Merchant.com THANK YOU FOR YOU HELP WIZ YOU ROCK !! TELL YOU HOW THINGS GO.
Now I have no power, out of all the 24 volt plug posts,there's 5 in all.I guess the 17 volt before, fed from the mainboard.I pluged voltage inverter back in to power supply,unpluged the mainboard and tested voltage, all's I could find is two 5volt power supplys live,thats it.So is it the power supply main?I have to say thanks to shinyo1 master wizard! and all the rest of you on this site. I would have been crying like a baby!!!!!!!! YOU ROCK THANK YOU
THE RED LIGHT IS ON BUT NO PICTURE NO BLU LIGHT
i have the same problem . So what shout i do
Same problem here. I turned it on & light went out. TV is not a year old.
RED LIGHT, no power will come on, I only use this TV for my PS3, so it rarly gets used. I just moved and its been connected for a few weeks. I went to use it for the first time, and NOTHING. Im very unimpressed with this peice of ****. If you are not watching 720p or higher, it looks like garbage. My dad just got a 52" LG and it still looks great in 480i. If i have to watch 480 on this Polaroid 3211-TLXB it looks so crappy, i just watch a 27"CRT and it blows this peice of **** away, hands down. Bottom line, This ******* light issuse is then end, now i have a 32" LCD POS Paper Weight, WHAT THE **** DO I DO NOW? Thanks Polaroid.
redlight no power
