SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
SOURCE: Somehow I have locked my Jazzy 6 Select Electric
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
SOURCE: Jazzy Select 6 Indoor Power Wheelchair: Hi! I just inherited a used Pride Mobility Ja...
There should be a place to plug the charger in on the front of the joystick. It is a round three pin connector
SOURCE: Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
SOURCE: Just bought 2nd hand jazzy select 6 ultra v v slow !!
The unit can be programmed to run faster. Stop in to the local powerchair dealer in your area. Very quick and inexpensive fix. I would charge you only for my time. About 10minutes max.
