SOURCE: Pink and blue images occasionally on power up of DISH DVR
Tell me a little more about how the receiver is connected to the tv and if this is present on both tvs at the same time and lastly what brand and model of tv you have. I recently had an issue somewhat similar to this but need more information to make an educated hypothesis.
SOURCE: Re: 322 DTV Receiver - snowy screen on tv 2
Lets check the modulator set up at the main location TV 1. Press menu - 6-1-5 this will display how the TV 2 IS SET UP. It should say 22 air and if not use the arrow keys on the remote to change that info. Once you are done click done and go to the TV2 and see if it is working. It should be if you are set to view air or antenna channels on the TV2. If not there needs to be a few more things done to isolate the issue. Let me know and we will go from there. Thhanks for using Fix Ya.
SOURCE: Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
SOURCE: TV has screen saver that says Press
It sounds like the remote lost its function, you need to program it again, try this. Please press SAT at the top left of your remote for 5 seconds and then press RECORD three times. IF that does not work, access the system info from the TV1, location, readress that remote.
To readress that remote, try this. With the remote that is not working, please press and hold the SAT button. Once all the buttons light up, let go, and then press 9, then # (below 9). Press RECORD twice. Did the Remote Address change on the system info screen? If so, you are set!
http://tech.dishnetwork.com/departmental_content/TechPortal/index.shtml
SOURCE: Recently whenever we try to watch a recorded item
Guest,
Are you still having problems with your DVR receiver? Try unplugging the receiver for 10 seconds and plugging back in. The receiver will reboot and acquire satellite signal. If this doesn't fix the problem there may be an issue with the receiver. I hope this helps.
Ray Calo
DISH Network
It is possible the garage door opener is causing interference. I would just need some more information to provide you with a resolution.Because it happens on both remotes, are they both UHF? Around 5 to 5:30 PM does someone use the garage door opener? If so can you try re-creating the problem by manually using the door opener at a different time and see if it happens?You can post here with more information, and I will be sure to look into this further!Tommy FaustDISH Internet Response Team
