McCulloch Electric Chipper Shredder Logo
Gary Strauss Posted on Jan 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My McCollough 14 amp chipper shredder will not start. the shaft and cutter head spin freely. I just replaced the thermal circuit breaker. What else needs checking? Can you refer me to a local repai
I also need a new power pigtail, the power cord from the motor to be plugged into the power source.
Derrick Schultz
Level 3:
Top Expert:
  • McCulloch Master 11,405 Answers
  • Posted on Jan 19, 2019
Derrick Schultz
McCulloch Master
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2326835
Points
23972
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
1 Related Answer
Anonymous
  • 1015 Answers
  • Posted on Jul 29, 2011
SOURCE: The motor got hot & smoked so I assume I need
As for the motor two of the best suppliers that I have found are washer specialties or grainger industrial supply. They both have distributors nationwide so you should have no trouble finding one nearby.The screwdriver you can get at auto zone or napa. Hope this helps you. Thanks. For the motor you will need h.p. rating manufacture name voltage rating and shaft diameter. The model number would be helpful to.
Shredder #FS5. Blows the circuit breaker each time I move the starter to the start position. Every part of the head is clean of paper, etc.
It sounds like the cogs that drive the cutters are damaged or the spindle on which they run is bent. It requires stripping down the machine to see if this is so. It is very rare that any repair can be done. Looks like a new shredder...
DuroStar Eco-Shredder - replacement bolts for blade? I'm looking for replacement bolts for my Eco-Shredder. Sooner or later, the head on one will get stripped, so I want a spare. Couldn't find short ones...
You've found the right place buddy
I keep buying manuals from various websites so I can damn well help u in this..
what chipper is it btw? Like few websites have some manuals better while some have other brands better
2answers
Bridgewood 15" planer starts slowly then blows breaker
That sounds like a capacitor gone bad. My A/C motor did that too. Replaced the capacitor and all was well again.
Where can I buy a good portable chipper shredder online?
There are a wide variety of portable chippers available online. I bought my Earthquake 206cc Chipper/Shredder at http://www.powerequipmentdirect.com/cutters/portable-chipper-shredder.html.
How can I get my Craftsman Electric Chipper/Shredder to start - model no. 833.79985?
hello for heavy machinery
u will find a lot of wiring diagrams and circuit diagrams and stuff like this at few sites I know with service like
instant help any time
1helpful
I plug my shredder in and turn it on, it makes a short hum noise and then breaker trips and I cannot reset it.When it does reset it trips again Never used it
The breaker is tripping on an over current condition. This could be caused by the motor being stuck and not moving or some sort of short circuit. I suggest, with it unplugged, that you find a way to rotate the chipper head or the motor. May have to disassemble to accomplish this. If it will not turn it may be bound up and you are going to have to take apart anyway to remove the item.
Good luck, hope this helps.
I have a Mcculloch MCS2001 Electric Chipper/Shredder. I need to replace the V-Cutter and the Cutter(Blade). Any idea where I should go to get these?
i have a chipper too, and it started giving lot of problems 4 yrs ago, so I got this manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
How do you change the cutter blade on the TB Chipper?
I just did one!
There are two opposing threaded holes next to the shaft.
Screw in bolts and use a wheel or gear puller to remove.
You can use a socket that fits in the center bore for an extention of your gear puller.
auttozone or ayto supply rents for free w/deposit
Just replace compressor keep tripping circuit breaker
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
The fan motor could have been your problem all the time, because if the fan doesn't come on or runs slow, it causes high head pressure,
which causes high amps, which could trip your breakers.
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Top McCulloch Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a McCulloch Heavy Machinery Expert? Answer questions, earn points and help others
