The other night, I was texting just fine. I woke up and tried to send a text and my phone said "message not sent". I tried to resend the message about 3 times. I called the person i tried texting and they said that they tried texting me an hour before i tried texting them. I have all 4 bars. What's wronge??
SOURCE: Recipient Barred
TRY RENEWING PROXY SERVER FOR MEDIA NET. THIS SHOULD CORRECT THE MMS PROBLEM....
SOURCE: Text messages cannot be sent
I have been having the same problem with my P3300. I finally found a solution that worked for me. Here are the steps.
Go to:
Start menu
Settings
Connections Tab
SMS Service Icon
Then set SMS over: to gsm preferred
I was then able to send and receive sms with no problem.
I hope this helps out. Post back and let me know if this worked for you.
SOURCE: How do you send a group text message
I may be making this too simple, but since Outlook is what actually handles text/mms/email, you should just be able to type the first letter/number of your contact while you are in the "To:" field and the auto complete feature should prompt with a number of choices/emails/phone numbers. After you select a contact, the software auto populates a semi-colon and a space to allow to repeat to your hearts content. Hope this helped.
SOURCE: I am having problems downloading text messaging pictures to my g1
In the Market there is a program called "Save MMS" - that should assist.
SOURCE: texting situations
Are the people that are Tmobile are they having a problem receiving text from other people that they know are on the same carrier as you are. If so, that means there is a problem on the Tmobiles side....If not, it means you have a routing problem. If the problem is yours you will need to call your carrier so that they can take the necessary steps to have it corrected for you. Good luck
