SOURCE: konica minolta bizhub C252 printer Problem
You should be able to get Konica Direct to take care of it.
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
SOURCE: Konica Minolta Bizhub 350, for faxing on Windows Vista PC
Yes you need the Driver.
http://help.bt.konicaminolta.ca
You can find all the drivers and help you need there.
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
