When my granddaughter went to take drivers test they wanted her to turn headlights on while still in park. we are unable to figure out how to do this. owners manual not helpful.
SOURCE: 2004 Envoy AC works but does not come out the front vents. Only @ windshield
You most likely have a bad mode actuator. http://forums.trailvoy.com/showthread.php?t=40235
SOURCE: 2002 gmc envoy slt 4x4
Had the same concern. Had to take mine to the dealership and have them replace the system. Be careful when you change between the drives. Vehicle MUST be in park, of course started, and you can change the drive. WAIT until the light completely stops blinking before placing into gear or trying to change to another setting. When you change the setting, a gear arm raises or lowers, and resets. Listen and you can hear it. Often when the vehicle has sat for a while, or if the battery has been disconnected, you will hear it resetting. If this does not work, you have to take it into the shop to have the gear sensor repalced.
SOURCE: need fuse box diagram 2002 gmc envoy
If I remember correctly if you look at the back side of the fuse cover, it should tell you what the fuses are. Also in the owners manual in the index, under fuses, it should give you a diagram of the fuse location for the acc. outlets. Good luck. The fuse should be a 20 or 25A fuse.
SOURCE: The button on our 2004 GMC Envoy gear shift will not depress when
The brake rlease switch for the gearshift might need adjusted-replaced or the shifter itself might need adjusted
SOURCE: HOW DO I CHANGE MY FUEL FILTER ON MY 2003 GMC
Fuel Filter
Removal & Installation
2002-2004
To Remove:
NOTE: If a fuel filter is restricted, clean and inspect the inside of the fuel tank.
To Install:
