Question about Food Mixers
Preeti mixie stopped working
I brought a preeti silver eco plus mixer from india.i stay in USA.i got its power conversion to 110V.it suddenly stopped when preparing dosa batter.overload button also not responding.i brought it 2 mnths back,it was working well all these months.is there any service centre in USA?
  • 4 more comments
  • akshatharaj_
    akshatharaj_ Feb 24, 2012
    Same problem! I bought the same mixer today and it stopped suddenly after using it for 2min! (while preparing dosa batter). I dono wheather i can fix it or return it. Any solution?
  • akshatharaj_
  • jayashree May 29, 2013
    same problem in mine .Do u have a # to the chicago center for repairs?
  • Shama Jun 11, 2013
    Did you check the solution I wrote below?
  • MALARKODI SUBBAIYAN
    MALARKODI SUBBAIYAN Aug 11, 2017
    Same problem here, I unscrewed, and noticed the white wire is hanging without connected any where. Is it supposed to be connected any where?
  • Prajwal Kulkarni
    Prajwal Kulkarni Jun 26, 2018
    Same problem
    New Friend:
I know it is kind of late to answer this, but those who are looking anew for a solution to this problem might find this helpful so writing my experience. I also brought a Preethi mixie, 110V from India and in less than two uses of about 5-10min it stopped. I searched everywhere for a solution and even called service center in Chicago (yes, there is one in Chicago, IL) and finding it difficult to go there and get it repaired, I dared to open it.
I am glad I did as I noticed a connector wire (with a plastic seal/insulator) is burnt. It is a simple fix and I cleaned the burnt part and carefully exposed the wire a little bit more and connected it back to the other wire as it is supposed to and put the insulator back in its place. I started the mixer and its working now :)
I have been using it for a month now since I fixed it to make dosa batter, chutneys etc and it is still working. So I think this is the problem most of us had with mixer not working after few minutes of usage and even the overload button not working. Try this and let me know if this solved your problem.
Happy Cooking!
Posted on Feb 25, 2013
    Did you check the solution given below?
  • kazisajida13
    kazisajida13 Jan 29, 2014
    Shama can u put the picture of the thing you saying u fixed , meaning can you show me in pictures what you exposed
2 Suggested Answers
SOURCE:
  • 130 Answers
SOURCE: My Preeti Mixer grinder stopped working 750 watt,
Your circuit breaker (load protection button) was popping for a reason and that reason has evidently gotten much worse. Possible causes are a short circuit in the wiring of the motor or a heavy mechanical load on the motor such as a bad bearing. Here is the service manual for your mixer. It contains all the information you need to fix your problem.
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Once you have isolated the problem here is the parts list so that you can search the internet by part number for the replacement part.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Bob
Posted on Apr 19, 2010
I am doing a 110V to 220V conversion on my KSM 150 kitchenaid mixer. Do I need a RFI filter too ?
It will run fine without the filter if you choose to bypass it. If your 110 volt filter is not up to handling the 230 volts the filter will only go bang and smoke it won't harm anything else. I have looked at the capacitors on a 230 volt filter and they are 250v - 275v so just read what's on your 110v filter. What you need to change is the armature, the fields and the small phase board under the back cover..
Dec 16, 2017 | KitchenAid Food Mixers
What is the voltage required to run rival hand mixer?
This plugs into a standard 120v household outlet, it's only 150 watts, running 10 of these is like one hair dryer. Most products say 110v, 115v in the USA.
The actual voltage is around 120v at the breaker panel and around 118v at the outlet.
But all products marked 110v, 115, 117, all work on a standard outlet.
Apr 14, 2013 | Rival 150 Watts MX555-W Hand Mixer
My preeti lavender stopped workng suddenly
If its new, I would return it for warranty.
Dec 31, 2012 | KitchenAid ProLine 600 Stand Mixer
My sunbeam mixmaster is about 40 years old and suddenly stopped working
The running capacitor finally died. I used to be their factory service tech. You can change it easily by removing the back knob and the handle. The screws are under the silver buttons. The capacitor looks like a 3/4 x 1 1/4' tube with a small nib sticking out each end.
Dec 26, 2012 | Sunbeam 2366 MixMaster Series Hand/Stand...
I have Butterfly brand mixer grinder from India. While operating it went off due to overload, but it's not working now. I tried pressing the reset button but still no use. Now, I opened the machine and...
I have the same problem with Butterfly Ivory Plus mixer in India.... The mixer went off with over load. I pressed the reset button, but still the mixer wont start. Looks like a common prob with butterfly mixers.
Nov 02, 2010 | Food Mixers
I brought an MX-AC300 PANASONIC mixer grinder from india to usa.its not working.it's not start even once.can any one help me out on this .i used voltage coverter also.
did u check it( i mean whether it was working) in india if not look in to the warranty period and find out what u can do.. i have bought the same mixer and i'm going to take it to finland in a couple of months.. at present in india its working fine.. and one more qn is it the first time that it's not working.. or it stopped working.. coz too much of rotating might even harmed the mixer.. remember for this mixer it should not go more than 3 min..
Mar 29, 2010 | Food Mixers
Panasonic MX-216E - work when you shake it or tap some times..
I used to live in Mtn. View on Bryant St. next to the P.G.&E office, great town.
I have had appliances go as long as twenty years and never had the brushes go out, but it sounds kie that is your problem alright, this is very unusual I would contact Panasonic and see what they will do for you there is usually a one year parts warranty on small appliances, call them you have nothing to lose. I would call this a factory defect.
Feb 28, 2009 | Food Mixers
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Food Mixers Logo
11,269 people viewed this question
Top Food Mixers Experts
Bruce Showalter
eyecam
Marvin
Marvin
Are you a Food Mixer Expert? Answer questions, earn points and help others
