LG WM-2277HW Front Load Washer Logo
Posted on Oct 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Font Load Washer flashing error code FE - LG WM-2277HW Front Load Washer
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Oct 12, 2008
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751337
Points
5690
FE is Fill Error. If door is closed and washer is plugged in, FE means water is too high and water pump will turn on.
This happens most often when a water fill valve will not shut off completely, allowing water to continue to fill washer, sometimes very slowly. If you shut off one valve (where the hose comes from the household plumbing) at a time you may be able to tell which valve is the culprit. The hot is a single coil valve, the cold is a multi coil valve. Both are the part where the hoses connect onto the machine.
To access valves, remove 3 phillips head screws at the back of the washer holding the top cover in place. Slide the top back about two inches and lift it off.
2helpful
3answers
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
2answers
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
3helpful
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
3helpful
My LG washer TROMM displays the code FE what does that mean?
Overflow error.
Water level frequency is over 213
If FE is displayed the drain pump will kick in to prevent flooding.
Might be a bad water valve OR it could be a clogged water pressure tubing (from tub to control)
Your tech service manual and some notes are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
1helpful
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
1helpful
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
2helpful
FE code displays
Yes, the water valves are easy to locate and replace.  Just remove the top panel to get access to them.  There are 2 of them.  You need to know which one to replace before ordering the correct part from LG.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
