Check this link
Braun Thermometer Owner Manual ManualsOnline com
SOURCE: Can you change the temp
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
SOURCE: I have a braun thermoscan 6022 after it displayed
Ambient temperature is not within the allowed operating range (10 - 40 °C or 50 - 104 °F).
Allow the thermometer to remain for 30 minutes in a room where the temperature is
between 10 and 40 °C or 50 and 104 °F.
Here is a link to the manual if you should need it:
http://braun.kaz.com/files/IRT33020COGB,%20F,%20E,%20P.pdf
