Question about Intel DG31PR Motherboard
No boot, Intel Classic DG31PR, had been working ok
I have DG31PR with Intel Quad processor, 2gb memory. PC has been working fine for 5 months. Overnite shut down automatically (per power config). Unable to boot next morning. Green power light on, fans run. No red CPU light at any time. Swapped power supply with itentical. No help. Have checked all connections. With power off, pulled battery. Then reinstalled. No help. XP pro, latest SP.
  • 5 more comments
  • Anonymous Oct 12, 2008
    No beeps at any time. I was using both memory slots 1gb each. I just pulled both memory cards and re-powered. No boot. No beeps. Reinstalled both memory and re-powered. Still no beeps or boot.
    Monitor is blank. No changes to computer configuration in last few months. Nothing added or deleted. Was working fine during day. Shut down overnight (auto). Would not boot in morning. No storms. I changed out power supply with identical new one, no help.
    The green power led comes on when pressing power button. Power supply fan comes on, CPU fan on, little green light on motherboard is on. Otherways nothing. Pressing reset button doesn't do anything (I guess nothing to reset). Pressing and holding power button for a few seconds turns off power, like normal. No indication of hard drive operation. No red HD light. No monitor display.
  • Anonymous Oct 13, 2008
    Perhaps I'm not explaining it well. Even without a monitor the PC should boot, and show some hard drive operation. Doesn't do anything except fans and green power light. Monitor is fine and shows no signal.
  • azis93 Jan 21, 2009
    I have xactly da same prob. plz help
  • Anonymous Mar 12, 2009
    I too have the same problem . .. hoping for ur response
  • Anonymous May 06, 2009
    nothing happen no memory no beep
    Intel DG31PR just running green light. fan is runnig .
Similar thing happened to me, the problem found was that the bios had somehow gotten busted. so got it fixed.
Posted on Oct 26, 2008
Problem was failed montherboard. I replaced and everything is fine. Thanks for responses. John.
Posted on Oct 17, 2008
  • 94 Answers
Do you get any beeps sounds when u start your computer? Try removing the memory card and insert it again or try another memory card slot.
Posted on Oct 12, 2008
    What do you get on your monitor screen? Did you install or add any device on your computer prior to the problem? If you did, try to remove one of the devices like a USB hub. Your computer may be getting enough power from your power supply.
    I think, it is just the connection between your monitor and the CPU or the power on the monitor is off. Can also be the video card. Are you using the video card from your motherboard or external video card? IF external, you may try to unplug and replug it.
SOURCE:
Telikin bios
They run on Linux. There is a BIOS, but I don't know if it's locked out though.
The Telikin Freedom looks like a full laptop
  • Intel Quad Core 1.83GHz Processor
  • 4GB SDRAM
  • 500GB hard drive
It should run any modern windows.
The other ones listed are very low specs.
Telikin Breeze
  • Intel dual core 1.8GHz processor
  • 2GB SDRAM
  • 16GB solid state drive
Telikin Silver
  • Intel J1900 Celeron Quad Core processor, 2.4GHz
  • 2GB DDR3 Memory
  • 32GB Solid State drive
Unless you can find a way to upgrade the SSD,
Windows 7 fills up 30GB by itself, 8/8.1/10 are also out of the question. None of these work well with only 2GB memory either.
You might be able to run Windows XP on the 32GB Silver.
Jul 18, 2016 | Computers & Internet
Fiteed new quad core CPU and 4gb of Ram, when started up getting no signal detected on the monitor. Can anyone help?
Let's back up a second.
A) What HP model is it? (P/N. Product Number. Back of desktop computer tower)
B) What model number of Intel quad core is it?
C) What are the manufacturer ID number/letters on the ram memory module/s?
I need to know what Northbridge chip is used on the motherboard, to know if it will support the particular Intel quad core you're trying to use.
This I can hopefully obtain from HP Support, by looking at the specifications for the motherboard.
(This technology does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip is part of the motherboard chipset.
So aptly named, because on a desktop computer motherboard it sits to the 'North', for one.
(Under the Processor)
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics technology.
A graphics card plugged into a PCI slot, and Integrated Graphics, is Not high-speed graphics.
The Southbridge chip handles the slower capabilities of the computer.
Motherboard Diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
List of Intel Chipsets, and more specifically the one's that can handle Intel quad core processors,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Secondly;
Make sure the Ram Memory you installed is Compatible.
If the motherboard supports 4GB of ram, make sure it is in the correct ram slots if using two sticks of ram, or four sticks.
There HAS to be a ram memory module ('Stick') in Slot 1. (DIMM 1)
EACH ram memory slot has a Maximum Amount.
For example if there are 4 ram slots, and the Maximum Total Amount of ram memory is 4GB, each ram slot may have a maximum of 1GB.
It may, or may not be that you can use Slot 1 and Slot 2, and use two 2GB sticks.
Third:
Always go slow when upgrading.
Install the Processor first, boot the computer up, see how it works.
THEN shut the computer down, unplug from power, observe Anti-Static Precautions, and install 2GB of ram memory.
Works?
Install the other 2GB.
BIOS has to recognize the changes.
Fourth:
Are you sure your Power Supply is adequate to support the quad core, and the added ram memory?
Post back in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | HP Computers & Internet
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    My computer does not work with two 2GB RAMs
    I think, one, out of the two is defected. Make pair with other memory or try changing the slots and vice versa. And for dual channel memory mode, you must installed two identical memory. I mean sizes and makes may different, but bandwidth should be identical to each other.
    Jul 30, 2010 | Intel DG31PR Motherboard
    What is the minimuim requirements on resident evil 5
    Yeah maybe but it gonna be SLOW so I dont recommend it. you should have a better computer.
    Resident Evil 5
    Publisher: Capcom
    Developer: Capcom
    Minimum System Requirements
    OS: Windows XP
    Processor: AMD Athlon64 X2/Intel Pentium D series
    Memory: 1 GB
    Hard Drive: 8 GB Free
    Video Memory: 256 MB (ATI Radeon HD 2400/NVIDIA GeForce 6800)
    Sound Card: DirectX Compatible
    DirectX: 9.0c
    Keyboard and Mouse
    DVD Rom Drive
    Recommended System Requirements
    OS: Windows Vista
    Processor: AMD Phenom X4/Intel Core 2 Quad series
    Memory: 2 GB
    Video Memory: 512 MB (ATI Radeon HD 4800/NVIDIA GeForce 9800)
    DirectX: 10
    Keyboard and Mouse
    DVD Rom Drive
    Aug 17, 2009 | Intel DG31PR Motherboard
    Intel dg31pr motherboad not booting.
    Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
    Jun 07, 2009 | Intel DG31PR Motherboard
    Intel DG31PR Motherboard not booting
    You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
    "If some thing is working, don't try to fix it" :) .
    Jan 28, 2009 | Intel DG31PR Motherboard
    Intel Dual Core 2.0 GHz Sytem hangs after boot
    During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
    Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
    Intel DG31PR Motherboard Logo
    808 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    Ekse
    Joe Negus
    Joe Negus
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
