Question about HP Photosmart M537 Digital Camera
Is my hp photosmart m537-001 compatible with kingston micro sd adapter?
I bought kingston micro sd adapter to store pictures on my hp photosmart m537-001 but it says that the card is unreadable, meaning to say i have to format it and i did but still it says unable to format.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Make sure you're using a microSD card, 2GB and smaller, and not a higher-capacity microSDHC card.
Posted on Sep 16, 2012
  • kakima Sep 16, 2012
2 Suggested Answers
SOURCE:
etaf
  • 779 Answers
SOURCE: what does charging flash on photosmart m537 mean?
The flash gun needs to have a high charge available before it can flash - this can take a few seconds to charge fully ready to give off a full flash "flash" As batteries get older and uncharged - it takes longer to reach the correct charge on the flash
Hope that helps
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 31, 2010
Tip
Long boot up time on MSI netbook when Kingston micro SD adapter installed
Found a strange symptom on a MSI netbook with Windows 7 Starter OS; it would take a long time to boot up. After the initial Windows splash display, the screen would go blank, and take several minutes to come back to the logon screen.
After many trials with reloading the whole drive, checking disks, finally isolated it to the presence of the Kingston micro SD adapter, but without a micro SD card in the adapter.
Without a flash card in the adapter, it apparently tries to access it regardless, and hangs things up for a long time. Removed the adapter, and it booted and shut down almost instantly in comparison.
The adapter is not a simple pass through of the micro SD card, so if there is no flash card installed, leave it unplugged, or it may slow things down considerably.
Didn't find anything on a search related to this symptom and problem, so I thought I'd note it just in case anyone else runs into this situation, maybe save them some time troubleshooting...
on Jul 13, 2010 | Computers & Internet
Micro sd adapter driver
"device driver software was not successfully installed"
Find the correct driver for your computer and operating system.
Mar 17, 2014 | Kingston Electronics - Others
I have an HP 320 and tried to use my newly purchased Kingston 2GB memory card. I get the message
The HP Photosmart 320 camera is too old to accept a 2 GB card. It can only handle an SD memory card up to 128 MB. (The detailed specs for the camera are available from HP here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buy60403&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=75944 or refer to the User Manual, also available from HP's support site for the Photosmart 320. The information is on page 61 (page 63 of the pdf).) Amazon lists a Kingston 128MB card for ~$9 here: http://www.amazon.com/Kingston-128-Digital-SD-Package/dp/B00006BBY4 .
I hope this helps and I wish that I had better news for you.
May 18, 2012 | Electronics - Others
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 | Cameras
Just bought Kingston 2GB SD Card for Boss Micro BR but when maching turned on,its frozen on KEEP POWER ON! SONG LOADING!
This is likely a compatibility issue. Turn power off and remove the card and make sure the unit comes back to life.
SD card compatibility can be a problem.
You might want to go to VSPLANET.com as there is a lot of info on forums about recorders.
Jun 03, 2010 | Boss Micro BR Digital Recorder
How shall i put in a kingston 1gb micro sd in a All in 1 card reader
You should have 2 components with your micro SD card. The card, a small adaptor and a large adaptor. All you need to do is see what size adaptor your read needs. You place the card in the tiny slot in the adaptor and slide it in the reader. The computer will find the micro SD and install the driver to read it. Then it will give you an option to open the files. That is how 99% of them work.
Sep 30, 2009 | Fuji xD MP3 Player
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
Hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Feb 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Can I transfer pictures from my computer back to my chip
If you have a micro SD card that has an adapter for your computer you can plug it into your computer and open it inside an explorer window and drag and drop pictures from your computer folder to your picture folder on the micro SD card. You can definitely do it. I just did it for a friend of mine and it works perfectly. That's why they sell the micro SD cards with the adapters for your computers...so you can transfer things back and forth. Mine is the 8GB Kingston that comes with adapters from micro to mini to regular SD card and to USB port. I bought it from Newegg.com for under $20.
Nov 27, 2008 | LG VOYAGER VX10000 Cellular Phone
HP Photosmart M537 Digital Camera Logo
119 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
