I had opened a problem last night with a support guy called "welcomejee" but the Laptop I was using flaked out on me, Girlfriend's son's.??? What I need is to get the TV back to the factory default for initial power on. The manual intructs you to choose either Area 1 or Area 2 and then there are different options and procedures for what Area your in. The big problem is the manual doesn't really give you any real information about differences between the two. Area 1 looks like mainly US and Canada but Area 2 is Russia, Eastern Europe and SouthEastr Asia. Since I am in the United Kingdom I went with Area 2 as it defaulted to it when that screen was displayed but now I can't get it to autoscan and find any channels and you can only manual search and fine tune using the Area 1 option. This is a multi-system TV connected to a SKY Plus Digital Cable box via a coax cable from the RF1 Out port to the back of the flat screen. I'm an IT guy with a company called General Dynamics and have lived here in the UK for 11 years, I'm familiar with Video setup and know how to tune in a TV over here and what connections are required, my only problem is I don't know how to get this particular JVC TV back to origianal factory settings so I can start over with the Area 1 option as the Area 2 won't find any channels and after troubleshooting it it seems the solution is to use Area 1.
Re: Factory Reset for JVC LT-32X18 Initial Power On
Try a hard reset first - Unplug TV from power source and remove all cable for about an hour. Then reconnect everything and see if it works..Let me know how it goes.
warranty requirements , on hidden defects.
no defects are expected within 4 years for just domestic use.
call your dealer , write to the importer, about the fault its not a JVC point to make products for only 2 years lifetime.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Channel guard and V-Chip
settings are protected by a four-digit lock code. Your TV comes preset
with a lock code of 0000
You may change the code to any four-digit number you wish. To
change the lock code, follow the steps below.
Press the MENU button
To "Initial Setup"
To enter
To "Set Lock Code"
To operate (Password input screen will appear)
Enter the password by using the 10 button
keypad
The Set Lock Code screen will appear
To set the password, use the 10 button keypad
Press the OK button to finish your lock code is now set
I have a problem with JVC Plasma TV having a split-screen and i can't get rid of it. Last night an on-line guy told me how to do it with a remote...but we don't have an OEM remote so the reset button does not work(neither does the OK button) and then another guy told us to push the reset buittton on the back twice. Well, we got the TV down and can't find the reset button...or is it on the back of the TV turner?
Does anyone out their have another suggestion?
btw, the cover of the TV looks like it has about 40 screws on the back..
1. Hold [menu] and [vol-] button on the side of the TV 2. while holding these, press the [power] button on the side of TV (NOT remote) 3. blue light comes ON and stays ON 4. wait 10 seconds then let go of [menu] and [vol-] 5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
is the power cord good leave it disconect over night try it in the morning or power bar those thing are not good for life hope it work take care cheers
