HAVE ALOT OF PROBLEMS WITH THIS PRINTER. ONE DAY IT WILL PRINT THE NEXT DAY IT WILL NOT PRINT. HAVE REINSTALLED IT SEVERAL TIMES. TODAY I REINSTALLED IT BECAUSE I TOTALLY LOST THE ICON FOR THE HOME CENTER. AFTER REINSTALLING IT THE ICON IS BACK, BUT NOW IT WILL NOT SCAN CODE 100-2105.ERROR OCCURS WHILE OPENING SCANNER, CHECK STATUS AND CONNECTION
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
SOURCE: kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
SOURCE: kodak esp 3200 how to put back door back
yes i am trying to install my kodak 3200 series printer but keeps telling me there is no network connection.. my internet is on.. what's going on...
SOURCE: My Kodak esp 3200 series printer wont acknowledge
Is this a genuine ink? If not then try removing and inserting a few times. If this does not work then unplug printer, leave for a few minutes then plug in and turn on. Some non-genuine inks (and some genuine) just do not ever work though.
SOURCE: Just bought a Kodak printer
The printer USB cables are easily avaialble at any computer accessories shop & are not expensive.
SOURCE: I have a paper jam in my Kodak ESP 3200 series
Please check the link below,
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01093/ESP3200Series_XUG_GLB_en.pdf
Page 7 Printer Overview point 6 is the rear clean out area.
Hope this helps
