SOURCE: Changing main greeting
You need to go into Feature 983 system admin. You need to get the password though.
SOURCE: How do I listen to by mesasges on a Nortel T7208
To access your voice mail messages either press your open voice mail key (if programmed) or enter feature 981.
SOURCE: T7208 Nortel Norstar phone system - how to
unfortunately when a message is deleted... it is deleted unless you have a back up
SOURCE: cant change time and date on nortel t7208 phone
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Testimonial: "With clarification that I gave on steps I took and what were results within three questions figured out the problem and solved it. Thank you very muc"
SOURCE: How do you change names on a Nortel T7316 phone?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
