Baby Gear Logo
Anonymous Posted on Oct 11, 2008
Stroller won't collapse for storage
I bought a second-hand stroller and cannot get it to collapse. There is a lever on the handle that looks as if it may have some function to help with collapsing; however, I cannot get the lever to budge.
Can you help me please?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
900
Points
I figured out how to collapse the stroller....There is a black button about 2 inches in length underneath the handle, slide that to the left and at the same time press the 3 inch yellow button on the front of the handle....the stroller collapses forward for storage.
I have a graco stadium duo stroller. I have collapsed it easily by using mechanism on handle but can't unfold it. I have no instruction manual.
While standing next to folded stroller , place one hand on the front seat& another on the handle & pull handle up. This unlocks the stroller with a click (this separates the front & rear seats), then just continue to pull on the handle till it opens fully& clicks into place!!! I hope you find this helpful!!
2helpful
I havr bought secondhand Greco pushchair for grandson, and cannot collapse it! can you help
On the handle of the stroller/pushchair there should be a grip that has a red button. Push the button and twist the grip away from you. There should also be a red grip on the side of the stroller about half way down. Pull that and twist the handle at the same time and push the stroller down. It should collapse.
1helpful
Collapse stroller
Look for sliding levers on sides and you can,
Quinny buzz stroller keeps collapsing when in use
Hi if you bought it within 60 days you can open up a claim on ebay & get a full refund. i sell them in perfect condition & would never sell 1 that is faulty. The only other option is if you are putting bags on the handle this will make if fold up on itself. contact me @ [email protected]
21helpful
2answers
I just bought a Reebok jogging stroller second-hand and can not figure out how to get it to collapse.. any advice?
I just had the same problem. Mine has two red brackets on either side up near the handle. You pull them up toward you and it should collapse.
I have a used Fisher Price stroller but no instruction manual. How do I collapse the Stroller? Does the back lower to allow a baby to sleep? If so, how? This stroller has all the 'bells and whistles'...
The stroller has two struts that attach to the top handle where you push. Feel along the struts from bottom to top; about 1/3 of the way from the top (2/3 from the bottom), you will find 2 little "triggers", one on each side. The right-hand trigger will have a small button on it. Simultaneously press the small button and pull both triggers towards you. The stroller will collapse.
How to fold the Graco Stroller 6001BCL1
Take the carrier off by raising the handle and then lifting the handle with one hand as you pull the red handle on the back of the carrier with the other hand. Set the carrier aside and stand behind the stroller. There should be 2 matching plastic 'things' on either side of the stroller, just under the rubber handle. Put your thumbs on the rubber handle and your first 2 fingers on those plastic pieces. Pull those plastic pieces up with your 2 fingers and the stroller will collapse. I hope this helps!
10helpful
2answers
I cannot close milano stroller
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
2helpful
5answers
Bertini M5 Shuttle
hi I think I could help I bought a bertini shuttle as well if you stand behind the pram on the right run your hand down the right side of the hood there is a push up lever there mine is grey ok you need to push the grey? lever but also on the left and right there is a black lever you must push up al together hope this helps good luck from debbie
Top Fisher Price Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
john h
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
