Shuts off when game inserted
I have experienced the same shutdown problem, and solved it in 10 minutes with the following procedure:
1) Clean the cartridge and system components with rubbing alcohol...2) Take out the batteries...3) Hold the on/restart button for anywhere from 10-45 seconds...4) Put batteries back in and put a game in...5) Power it up...
In some cases (like mine) it is due to a dry solder contact holding the cartridge slot to the board. Some games work when they are positioned a certain way in the slot (notice you can move the cartridge back and forth slightly when it is inserted). Yes, cleaning the cartridge contacts can help as a process of elimination, but the continued forcing of games into the system over time will eventually lead to this issue. It can be fixed if you have a little electrical knowledge and a heat gun or soldering iron.
Make sure the system is turned off before inserting the cartridge.
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Yeah, just cleaning the contacts on the game cartridges with alcohol did the trick for me. I also did the trick with removing the batteries and holding down the power button for 45 seconds but I am not sure if that did anything.
It still works when turned on and no game inserted...you know, the little character that bounces up and says "V.smile!". Other than that, every time I plug in ANY cartridge, it shuts off or screen stays blank OR screen splits to two different colors: red and black, green and black, or orange and black....NO idea whats going on, but extremely frustrating!!!
I have same problem, just bought a new AC Adaptor yesterday and the problem still occurs when that is plugged in.
I have the same problem..bought new AC adaptor yesterday and the problem still occurs when that is plugged in. Some games work, some don't.
The same thing happens to our system. Any suggestions?
system turns off when games inserted
Same EXACT problem as the post on 10-20-08. We have about 6 different games and none work. This unit has only had light use...probably about 4 hrs. of total use. Very frustrating. When turned on w/o a game we get the startup screen but putting a cartridge in makes it go black.
i will join the club on this one. i get power with one game and then change games i lose power and mix and match. some times it works and most of the time it dosent. seems to be some sort of power problem????? i am Puzzled.
Just curious if anyone's problem was solved with the solution below. I've tried it and am not having any luck. Before I tried the reset switch, the screen went black, now the screen is split. The on/off buttons don't respond either. If the "On" button is lit up, it won't turn off without unplugging it.
same problem - insert the cartridge and it turns off. Tried the reset button, cleaned with pressurised air and am seriously considering opening up the darned thing!
when i turn on the vsmile it repeats itself on the introduction, and when i put a game cartriged in it goes blank. I would like to get it fixed
Same thing!!!!!!!!!!!! I power on and it comes on but when i insert the game NOTHING!!!!!!!!! I don't think I will ever buy another one?
As soon as I plug the cartridges in, the power turns off. I have tried the reset and the power hold but still nothing,.Very frustrating as we have used this maybe 4 hours in the last year!
I have the exact same problem as everyone else! If so many people are having this problem why isn't v-tech doing something about it????
