SOURCE: my machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
SOURCE: my xerox workcentre pro 420 shows me code u4, how
p/l call to xerox cust care center this bater solutions
